RTEMS Logo
RTEMS 4.8.1 On-Line Library
Stack Bounds Checker stack_checker_report_usage - Report Task Stack Usage
25.4.2: stack_checker_report_usage - Report Task Stack Usage
CALLING SEQUENCE:
procedure Stack_Checker_Report_Usage;
STATUS CODES: NONE
DESCRIPTION:
This routine prints a table with the peak stack usage and stack space allocation of every task in the system.
NOTES:
NONE
Copyright © 1988-2007OAR Corporation
