RTEMS Logo
RTEMS 4.8.1 On-Line Library
I/O Manager IO_READ - Read from a device
16.4.8: IO_READ - Read from a device
CALLING SEQUENCE:
NOT SUPPORTED FROM Ada BINDING
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - successfully initialized
RTEMS.INVALID_NUMBER - invalid major device number
DESCRIPTION:
This directive calls the device driver read routine specified in the Device Driver Table for this major number. Read operations typically require a buffer address as part of the argument parameter block. The contents of this buffer will be replaced with data from the device.
NOTES:
This directive may or may not cause the calling task to be preempted. This is dependent on the device driver being invoked.
Copyright © 1988-2007OAR Corporation
