RTEMS Logo
RTEMS 4.8.1 On-Line Library
I/O Manager IO_UNREGISTER_DRIVER - Unregister a device driver
16.4.2: IO_UNREGISTER_DRIVER - Unregister a device driver
CALLING SEQUENCE:
NOT SUPPORTED FROM Ada BINDING
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - successfully registered
RTEMS.INVALID_NUMBER - invalid major device number
DESCRIPTION:
This directive removes a device driver from the Device Driver Table.
NOTES:
Currently no specific checks are made and the driver is not closed.
Copyright © 1988-2007OAR Corporation
