A signal set is built by a bitwise OR of the desired
signals. The set of valid signals is RTEMS.SIGNAL_0
through
RTEMS.SIGNAL_31
. If a signal is not explicitly specified in the
signal set, then it is not present. Signal values are
specifically designed to be mutually exclusive, therefore
bitwise OR and addition operations are equivalent as long as
each signal appears exactly once in the component list.
This example demonstrates the signal parameter used
when sending the signal set consisting of
RTEMS.SIGNAL_6
RTEMS.SIGNAL_15
, and
RTEMS.SIGNAL_31
. The signal parameter provided
to the rtems.signal_send
directive should be
RTEMS.SIGNAL_6 or RTEMS.SIGNAL_15 or RTEMS.SIGNAL_31
Copyright © 1988-2007OAR Corporation
