clearerr
- Clear file or stream error indicator
fclose
- Close a file
feof
- Test for end of file
ferror
- Test whether read/write error has occurred
fflush
- Flush buffered file output
fgetc
- Get a character from a file or stream
fgetpos
- Record position in a stream or file
fgets
- Get character string from a file or stream
fiprintf
- Write formatted output to file (integer only)
fopen
- Open a file
fdopen
- Turn an open file into a stream
fputc
- Write a character on a stream or file
fputs
- Write a character string in a file or stream
fread
- Read array elements from a file
freopen
- Open a file using an existing file descriptor
fseek
- Set file position
fsetpos
- Restore position of a stream or file
ftell
- Return position in a stream or file
fwrite
- Write array elements from memory to a file or stream
getc
- Get a character from a file or stream (macro)
getchar
- Get a character from standard input (macro)
gets
- Get character string from standard input (obsolete)
iprintf
- Write formatted output (integer only)
mktemp
- Generate unused file name
perror
- Print an error message on standard error
putc
- Write a character on a stream or file (macro)
putchar
- Write a character on standard output (macro)
puts
- Write a character string on standard output
remove
- Delete a file's name
rename
- Rename a file
rewind
- Reinitialize a file or stream
setbuf
- Specify full buffering for a file or stream
setvbuf
- Specify buffering for a file or stream
siprintf
printf
scanf
- Scan and format input
tmpfile
- Create a temporary file
tmpnam
- Generate name for a temporary file
vprintf
- Format variable argument list
Copyright © 1988-2007OAR Corporation
