RTEMS CPU Architecture Supplement
As discussed above, the call instruction does not automatically save any registers. The save and restore instructions are used to allocate and deallocate register windows. When a register window is allocated, the new set of local registers are available for the exclusive use of the subroutine which allocated this register set.
Copyright © 1988-2007OAR Corporation
