BSP and Device Driver Development Guide
There is a Makefile.am
in most of the directories in a BSP. This
class of Makefile lists the files to be built as part of the driver.
When adding new files to an existing directory, Do not forget to add
the new files to the list of files to be built in the Makefile.am
and run bootstrap
NOTE: The Makefile.am
files are ONLY processed by
bootstrap
and the resulting Makefile.in
files are
only processed during the configure
process of a RTEMS build. Therefore, when developing
a BSP and adding a new file to a Makefile.am
, the
already generated Makefile
will not automatically
include the new references unless you configured RTEMS with the
--enable-maintainer-mode
option.
Otherwise, the new file not being be taken into account!
If adding a new directory, be sure to add it to the list of
automatically generated files in the BSP's configure.ac
script.
Copyright © 1988-2007OAR Corporation
