procedure Task_Start ( ID : in RTEMS.ID; Entry_Point : in RTEMS.Task_Entry; Argument : in RTEMS.Task_Argument; Result : out RTEMS.Status_Codes );
RTEMS.SUCCESSFUL - ask started successfully
RTEMS.INVALID_ADDRESS - invalid task entry point
RTEMS.INVALID_ID - invalid task id
RTEMS.INCORRECT_STATE - task not in the dormant state
RTEMS.ILLEGAL_ON_REMOTE_OBJECT - cannot start remote task
This directive readies the task, specified by tid, for execution based on the priority and execution mode specified when the task was created. The starting address of the task is given in entry_point. The task's starting argument is contained in argument. This argument can be a single value or used as an index into an array of parameter blocks.
The calling task will be preempted if its preemption mode is enabled and the task being started has a higher priority.
Any actions performed on a dormant task such as suspension or
change of priority are nullified when the task is initiated via
the rtems.task_start directive.
Copyright © 1988-2007OAR Corporation
