RTEMS Logo
RTEMS 4.7.99.2 On-Line Library
RTEMS FTP Daemon
PREV UP NEXT Bookshelf RTEMS Network Supplement
5.1: RTEMS FTP Daemon
  • Configuration Parameters
  • Initializing FTPD (Starting the daemon)
  • Using Hooks
  • The RTEMS FTPD is a complete file transfer protocol (FTP) daemon which can store, retrieve, and manipulate files on the local filesystem. In addition, the RTEMS FTPD provides ``hooks'' which are actions performed on received data. Hooks are useful in situations where a destination file is not necessarily appropriate or in cases when a formal device driver has not yet been implemented.
    This server was implemented and documented by Jake Janovetz (janovetz@tempest.ece.uiuc.edu).
