RTEMS Logo
RTEMS 4.7.3 On-Line Library
Write the Driver IOCTL Function
PREV UP NEXT Bookshelf RTEMS Network Supplement
2.11: Write the Driver IOCTL Function
This function handles ioctl requests directed at the device. The ioctl commands which must be handled are:
SIOCGIFADDR
SIOCSIFADDR
If the device is an Ethernet interface these commands should be passed on to ether_ioctl.
SIOCSIFFLAGS
This command should be used to start or stop the device, depending on the state of the interface IFF_UP and IFF_RUNNING bits in if_flags:
IFF_RUNNING
Stop the device.
IFF_UP
Start the device.
IFF_UP|IFF_RUNNING
Stop then start the device.
0
Do nothing.
