RTEMS CPU Architecture Supplement
Although RTEMS supports 256 interrupt levels, the i386 only supports two -- enabled and disabled. Interrupts are enabled when the interrupt-enable flag (IF) in the extended flags (EFLAGS) is set. Conversely, interrupt processing is inhibited when the IF is cleared. During a non-maskable interrupt, all other interrupts, including other non-maskable ones, are inhibited.
RTEMS interrupt levels 0 and 1 such that level zero (0) indicates that interrupts are fully enabled and level one that interrupts are disabled. All other RTEMS interrupt levels are undefined and their behavior is unpredictable.
