rtems_status_code rtems_rate_monotonic_get_status( rtems_id id, rtems_rate_monotonic_period_status *status );
RTEMS_SUCCESSFUL
- period initiated successfully
RTEMS_INVALID_ID
- invalid rate monotonic period id
RTEMS_INVALID_ADDRESS
- invalid address of status
This directive returns status information associated with the rate monotonic period id in the following data structure:
typedef struct { rtems_rate_monotonic_period_states state; uint32_t ticks_since_last_period; uint32_t ticks_executed_since_last_period; } rtems_rate_monotonic_period_status;
If the period's state is RATE_MONOTONIC_INACTIVE
, both
ticks_since_last_period and ticks_executed_since_last_period
will be set to 0. Otherwise, ticks_since_last_period will
contain the number of clock ticks which have occurred since
the last invocation of the
directive.
Also in this case, the ticks_executed_since_last_period will indicate
how much processor time the owning task has consumed since the invocation
of the rtems_rate_monotonic_period
directive.
This directive will not cause the running task to be preempted.
