RTEMS Logo
RTEMS 4.7.3 On-Line Library
Region Manager REGION_GET_SEGMENT_SIZE - Obtain size of a segment
PREV UP NEXT Bookshelf RTEMS C User's Guide
14.4.7: REGION_GET_SEGMENT_SIZE - Obtain size of a segment
CALLING SEQUENCE:
rtems_status_code rtems_region_get_segment_size(
  rtems_id  id,
  void     *segment,
  size_t   *size
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - segment obtained successfully
RTEMS_INVALID_ADDRESS - segment is NULL
RTEMS_INVALID_ADDRESS - size is NULL
RTEMS_INVALID_ID - invalid region id
RTEMS_INVALID_ADDRESS - segment address not in region
DESCRIPTION:
This directive obtains the size in bytes of the specified segment.
NOTES:
The actual length of the allocated segment may be larger than the requested size because a segment size is always a multiple of the region's page size.
