The timer manager provides support for timer facilities. The directives provided by the timer manager are:
rtems.timer_create
- Create a timer
rtems.timer_ident
- Get ID of a timer
rtems.timer_cancel
- Cancel a timer
rtems.timer_delete
- Delete a timer
rtems.timer_fire_after
- Fire timer after interval
rtems.timer_fire_when
- Fire timer when specified
rtems.timer_initiate_server
- Initiate server for task-based timers
rtems.timer_server_fire_after
- Fire task-based timer after interval
rtems.timer_server_fire_when
- Fire task-based timer when specified
rtems.timer_reset
- Reset an interval timer
