Getting Started with GNAT/RTEMS
This section describes how to configure and build RTEMS so that it is specifically tailored for your BSP and the CPU model it uses. There is currently only one supported method to compile and install RTEMS:
configure
and make
Direct invocation of configure
and make
provides more control
and easier recovery from problems when building.
This section describes how to build RTEMS.
