Getting Started with GNAT/RTEMS
Apply the patch using the following command sequence:
cd tools/binutils-2.10 zcat ../../archive/binutils-2.10-rtems-gnat-3.13p-20001107.diff | patch -p1
Check to see if any of these patches have been rejected using the following sequence:
cd tools/binutils-2.10 find . -name "*.rej" -print
If any files are found with the .rej extension, a patch has been rejected. This should not happen with a good patch file which is properly applied.
