rtems_status_code rtems_clock_get( rtems_clock_get_options option, void *time_buffer );
RTEMS_SUCCESSFUL
- current time obtained successfully
RTEMS_NOT_DEFINED
- system date and time is not set
RTEMS_INVALID_ADDRESS
- time_buffer
is NULL
This directive obtains the system date and time. If
the caller is attempting to obtain the date and time (i.e.
option is set to either RTEMS_CLOCK_GET_SECONDS_SINCE_EPOCH
RTEMS_CLOCK_GET_TOD
, or
RTEMS_CLOCK_GET_TIME_VALUE
) and the date and time
has not been set with a previous call to
rtems_clock_set
, then the
RTEMS_NOT_DEFINED
status code is returned.
The caller can always obtain the number of ticks per second (option is
RTEMS_CLOCK_GET_TICKS_PER_SECOND
) and the number of
ticks since the executive was initialized option is
RTEMS_CLOCK_GET_TICKS_SINCE_BOOT
The option
argument may taken on any value of the enumerated
type rtems_clock_get_options
. The data type expected for
time_buffer
is based on the value of option
as
indicated below:
RTEMS_CLOCK_GET_TOD
- (rtems_time_of_day *)
- (rtems_clock_time_value *)
- (rtems_interval *)
This directive is callable from an ISR.
This directive will not cause the running task to be
preempted. Re-initializing RTEMS causes the system date and
time to be reset to an uninitialized state. Another call to
rtems_clock_set
is required to re-initialize the
system date and time to application specific specifications.
