rtems_status_code rtems_task_set_note( rtems_id id, uint32_t notepad, uint32_t note );
RTEMS_SUCCESSFUL - task's note set successfully
RTEMS_INVALID_ID - invalid task id
RTEMS_INVALID_NUMBER - invalid notepad location
This directive sets the notepad entry for the task specified by id to the value note.
If id is set to RTEMS_SELF, the calling
task accesses its own notepad locations.
This directive will not cause the running task to be preempted.
The sixteen notepad locations can be accessed using the constants
RTEMS_NOTEPAD_0 through RTEMS_NOTEPAD_15.
Setting a notepad location of a global task which does not reside on the local node will generate a request to the remote node to set the specified notepad entry.
