The clock facilities of the clock manager operate upon calendar time. These directives utilize the following date and time structure for the native time and date format:
struct rtems_tod_control {
uint32_t year; /* greater than 1987 */
uint32_t month; /* 1 - 12 */
uint32_t day; /* 1 - 31 */
uint32_t hour; /* 0 - 23 */
uint32_t minute; /* 0 - 59 */
uint32_t second; /* 0 - 59 */
uint32_t ticks; /* elapsed between seconds */
typedef struct rtems_tod_control rtems_time_of_day;
The native date and time format is the only format
supported when setting the system date and time using the
rtems_clock_get directive. Some applications
expect to operate on a "UNIX-style" date and time data structure. The
rtems_clock_get directive can optionally return
the current date and time in the
following structure:
typedef struct {
uint32_t seconds; /* seconds since RTEMS epoch*/
uint32_t microseconds; /* since last second */
} rtems_clock_time_value;
The seconds field in this structure is the number of seconds since the RTEMS epoch of January 1, 1988.
