The input/output interface manager provides a well-defined mechanism for accessing device drivers and a structured methodology for organizing device drivers. The directives provided by the I/O manager are:
rtems.io_initialize
- Initialize a device driver
rtems.io_register_name
- Register a device name
rtems.io_lookup_name
- Look up a device name
rtems.io_open
- Open a device
rtems.io_close
- Close a device
rtems.io_read
- Read from a device
rtems.io_write
- Write to a device
rtems.io_control
- Special device services
