The region manager provides facilities to dynamically allocate memory in variable sized units. The directives provided by the region manager are:
rtems.region_create
- Create a region
rtems.region_ident
- Get ID of a region
rtems.region_delete
- Delete a region
rtems.region_extend
- Add memory to a region
rtems.region_get_segment
- Get segment from a region
rtems.region_return_segment
- Return segment to a region
rtems.region_get_segment_size
- Obtain size of a segment
rtems.region_resize_segment
- Change size of a segment
