RTEMS 4.7.0 On-Line Library
Concept Index
RTEMS POSIX API User's Guide
Concept Index
acquire ownership of file stream
add a signal to a signal set
associate stream with file descriptor
asynchronous file synchronization
asynchronous read
asynchronous write
broadcast a condition variable
cancel asynchronous i/o request
cancel execution of a thread
change access and/or modification times of an inode
change memory protection
changes file mode.
changes permissions of a file
changes the current working directory
changes the owner and/or group of a file.
check permissions for a file
close a message queue
close a named semaphore
closes a file.
compare thread ids
create a directory
create a new file or rewrite an existing one
create a process
create a thread
create an inter
create cancellation point
create session and set process group id
creates a link to a file
creates a symbolic link to a file
delay process execution
delay with high resolution
delete a directory
delete a signal from a signal set
destroy a condition variable
destroy a condition variable attribute set
destroy a mutex
destroy a mutex attribute set
destroy a thread attribute set
destroy an unnamed semaphore
detach a thread
determine if file descriptor is terminal
determine terminal device name
discards terminal data
duplicates an open file descriptor
dynamic package initialization
dynamically set the priority ceiling
empty a signal set
ends directory read operation
establish cancellation handler
examine and change process blocked signals
examine and change signal action
examine and change thread blocked signals
examine pending signals
execute a file
fill a signal set
generate terminal pathname
get character from stdin without locking
get character without locking
get clock resolution
get configurable system variables
get detach state
get directory entries
get effective group id
get effective user id
get environment variables
get group file entry for id
get group file entry for name
get inherit scheduler flag
get maximum priority value
get message queue attributes
get minimum priority value
get parent process id
get password file entry for uid
get process group id
get process id
get process shared attribute
get process times
get real group id
get scheduling parameters
get scheduling policy
get supplementary group ids
get system name
get the blocking protocol
get the current priority ceiling
get the priority ceiling
get the time of day
get the value of a semaphore
get the visibility
get thread id
get thread scheduling parameters
get thread scheduling scope
get thread stack address
get thread stack size
get time in seconds
get timeslicing quantum
get user id
get user name
get user name, reentrant
gets configuration values for files
gets current working directory
gets file status
gets foreground process group id
gets information about a file
gets terminal attributes
initialize a condition variable
initialize a condition variable attribute set
initialize a mutex
initialize a mutex attribute set
initialize a thread attribute set
initialize an unnamed semaphore
initialize time conversion information
is signal a member of a signal set
list directed i/o
lock a mutex
lock a mutex with timeout
lock a range of the process address space
lock the address space of a process
makes a directory
makes a fifo special file
manipulates an open file descriptor
map process addresses to a memory object
memory object synchronization
microsecond delay process execution
mount a file system
non
notify process that a message is available
obtain file descriptor number for this file
obtain the name of a symbolic link destination
obtain time of day
open a directory
open a message queue
open a named semaphore
open a shared memory object
opens a file
password file entry for name
poll to acquire ownership of file stream
poll to lock a mutex
put character to stdin without locking
put character without locking
queue a signal to a process
reads a directory
reads from a file.
reads terminal input baud rate
reads terminal output baud rate
receive a message from a message queue
reentrant determine terminal device name
reentrant extract token from string
reentrant get group file entry
reentrant get group file entry for name
reentrant get password file entry for name
reentrant get password file entry for uid
reentrant get user name
reentrant local time conversion
reentrant random number generation
reentrant struct tm to ascii time conversion
reentrant time_t to ascii time conversion
reentrant utc time conversion
register fork handlers
release ownership of file stream
remove a message queue
remove a shared memory object
remove cancellation handler
removes a directory entry
renames a file
reposition read/write file offset
resets the readdir() pointer
retrieve error status of asynchronous i/o operation
retrieve return status asynchronous i/o operation
return current location in directory stream
save context for non
save context with signal status for non
scan a directory for matching entries
schedule alarm
schedule alarm in microseonds
send a message to a message queue
send a signal to a process
send a signal to a thread
sends a break to a terminal
set cancelability state
set cancelability type
set detach state
set environment variables
set group id
set inherit scheduler flag
set message queue attributes
set process group id for job control
set process shared attribute
set scheduling parameters
set scheduling policy
set terminal attributes
set the blocking protocol
set the current locale
set the visibility
set thread scheduling parameters
set thread scheduling scope
set thread stack address
set thread stack size
set time of day
set user id
sets a file creation mask.
sets foreground process group id
sets terminal input baud rate
sets terminal output baud rate
signal a condition variable
suspend process execution
suspends/restarts terminal output.
synchronize file complete in
synchronize file in
synchronize file systems
synchronously accept a signal
synchronously accept a signal with timeout
terminate a process
terminate the current thread
truncate a file to a specified length
unlink a semaphore
unlock a mutex
unlock a range of the process address space
unlock a semaphore
unlock the address space of a process
unmap previously mapped addresses
unmount file systems
usecs delay process execution
wait for a signal
wait for asynchronous i/o request
wait for process termination
wait for thread termination
wait on a condition variable
wait on a semaphore
wait on a semaphore for a specified time
wait with timeout a condition variable
waits for all output to be transmitted to the terminal.
writes to a file
yield the processor
Copyright © 1988-2004
OAR Corporation
