RTEMS Logo
RTEMS 4.7.0 On-Line Library
Motorola M68xxx and Coldfire Specific Information CPU Dependent Information Table
PREV UP next Bookshelf RTEMS CPU Architecture Supplement
3.7.1: CPU Dependent Information Table
The MC68xxx version of the RTEMS CPU Dependent Information Table contains the information required to interface a Board Support Package and RTEMS on the MC68xxx. This information is provided to allow RTEMS to interoperate effectively with the BSP. The C structure definition is given here:
typedef struct {
  void       (*pretasking_hook)( void );
  void       (*predriver_hook)( void );
  void       (*postdriver_hook)( void );
  void       (*idle_task)( void );
  boolean      do_zero_of_workspace;
  unsigned32   idle_task_stack_size;
  unsigned32   interrupt_stack_size;
  unsigned32   extra_mpci_receive_server_stack;
  void *     (*stack_allocate_hook)( unsigned32 );
  void       (*stack_free_hook)( void* );
  /* end of fields required on all CPUs */
  m68k_isr    *interrupt_vector_table;
} rtems_cpu_table;
pretasking_hook
is the address of the user provided routine which is invoked once RTEMS APIs are initialized. This routine will be invoked before any system tasks are created. Interrupts are disabled. This field may be NULL to indicate that the hook is not utilized.
predriver_hook
is the address of the user provided routine that is invoked immediately before the the device drivers and MPCI are initialized. RTEMS initialization is complete but interrupts and tasking are disabled. This field may be NULL to indicate that the hook is not utilized.
postdriver_hook
is the address of the user provided routine that is invoked immediately after the the device drivers and MPCI are initialized. RTEMS initialization is complete but interrupts and tasking are disabled. This field may be NULL to indicate that the hook is not utilized.
idle_task
is the address of the optional user provided routine which is used as the system's IDLE task. If this field is not NULL, then the RTEMS default IDLE task is not used. This field may be NULL to indicate that the default IDLE is to be used.
indicates whether RTEMS should zero the Workspace as part of its initialization. If set to TRUE, the Workspace is zeroed. Otherwise, it is not.
is the size of the RTEMS idle task stack in bytes. If this number is less than MINIMUM_STACK_SIZE, then the idle task's stack will be MINIMUM_STACK_SIZE in byte.
is the size of the RTEMS allocated interrupt stack in bytes. This value must be at least as large as MINIMUM_STACK_SIZE.
is the extra stack space allocated for the RTEMS MPCI receive server task in bytes. The MPCI receive server may invoke nearly all directives and may require extra stack space on some targets.
stack_allocate_hook
is the address of the optional user provided routine which allocates memory for task stacks. If this hook is not NULL, then a stack_free_hook must be provided as well.
stack_free_hook
is the address of the optional user provided routine which frees memory for task stacks. If this hook is not NULL, then a stack_allocate_hook must be provided as well.
is the base address of the CPU's Exception Vector Table.
