RTEMS Logo
RTEMS 4.7.0 On-Line Library
Motorola M68xxx and Coldfire Specific Information Default Fatal Error Processing
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
3.5: Default Fatal Error Processing
  • Motorola M68xxx and Coldfire Specific Information Default Fatal Error Handler Operations
  • Upon detection of a fatal error by either the application or RTEMS the fatal error manager is invoked. The fatal error manager will invoke the user-supplied fatal error handlers. If no user-supplied handlers are configured, the RTEMS provided default fatal error handler is invoked. If the user-supplied fatal error handlers return to the executive the default fatal error handler is then invoked. This chapter describes the precise operations of the default fatal error handler.
