RTEMS Logo
RTEMS 4.7.0 On-Line Library
Motorola M68xxx and Coldfire Specific Information Calling Conventions
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
3.2: Calling Conventions
  • Motorola M68xxx and Coldfire Specific Information Processor Background
  • Motorola M68xxx and Coldfire Specific Information Calling Mechanism
  • Motorola M68xxx and Coldfire Specific Information Register Usage
  • Motorola M68xxx and Coldfire Specific Information Parameter Passing
  • Motorola M68xxx and Coldfire Specific Information User-Provided Routines
  • Each high-level language compiler generates subroutine entry and exit code based upon a set of rules known as the compiler's calling convention. These rules address the following issues:
    A compiler's calling convention is of importance when interfacing to subroutines written in another language either assembly or high-level. Even when the high-level language and target processor are the same, different compilers may use different calling conventions. As a result, calling conventions are both processor and compiler dependent.
