RTEMS Logo
RTEMS 4.7.0 On-Line Library
ARM Specific Information Interrupt Levels
PREV UP NEXT Bookshelf RTEMS CPU Architecture Supplement
1.4.2: Interrupt Levels
The ARM architecture supports two external interrupts - IRQ and FIQ. FIQ has a higher priority than IRQ, and has its own version of register R8 - R14, however RTEMS does not take advantage of them. Both interrupts are enabled through the CPSR.
The RTEMS interrupt level mapping scheme for the AEM is not a numeric level as on most RTEMS ports. It is a bit mapping that corresponds the enable bits's postions in the CPSR:
FIQ
Setting bit 6 (0 is least significant bit) disables the FIQ.
IRQ
Setting bit 7 (0 is least significant bit) disables the IRQ.
