RTEMS Logo
RTEMS 4.7.0 On-Line Library
Timer Manager TIMER_INITIATE_SERVER - Initiate server for task-based timers
PREV UP NEXT Bookshelf RTEMS C User's Guide
8.4.7: TIMER_INITIATE_SERVER - Initiate server for task-based timers
CALLING SEQUENCE:
rtems_status_code rtems_timer_initiate_server(
  rtems_unsigned32     priority,
  rtems_unsigned32     stack_size,
  rtems_attribute      attribute_set
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - Timer Server initiated successfully
RTEMS_TOO_MANY - too many tasks created
DESCRIPTION:
This directive initiates the Timer Server task. This task is responsible for executing all timers initiated via the rtems_timer_server_fire_after or rtems_timer_server_fire_when directives.
NOTES:
This directive could cause the calling task to be preempted.
The Timer Server task is created using the rtems_task_create service and must be accounted for when configuring the system.
Even through this directive invokes the rtems_task_create and rtems_task_start directives, it should only fail due to resource allocation problems.
