BSP and Device Driver Development Guide
The ata_initialize
routine is responsible for ATA driver
initialization. The main goal of the initialization is to detect and
register in the system all ATA devices attached to IDE controllers
successfully initialized by the IDE Controller driver.
In the implementation of the driver, the following actions are performed:
rtems_device_driver ata_initialize( rtems_device_major_number major, rtems_device_minor_number minor, void *arg ) { initialize internal ATA driver data structure for each IDE controller successfully initialized by the IDE Controller driver if the controller is interrupt driven set up interrupt handler obtain information about ATA devices attached to the controller with help of EXECUTE DEVICE DIAGNOSTIC command for each ATA device detected on the controller obtain device parameters with help of DEVICE IDENTIFY command register new ATA device as new block device in the system }
Special processing of ATA commands is required because of absence of multitasking environment during the driver initialization.
Detected ATA devices are registered in the system as physical block devices (see libblock library description). Device names are formed based on IDE controller minor number device is attached to and device number on the controller (0 - Master, 1 - Slave). In current implementation 64 minor numbers are reserved for each ATA device which allows to support up to 63 logical partitions per device.
controller minor device number device name ata device minor 0 0 hda 0 0 1 hdb 64 1 0 hdc 128 1 1 hdd 172 ... ... ...
