The dual-ported memory manager provides a mechanism for converting addresses between internal and external representations for multiple dual-ported memory areas (DPMA). The directives provided by the dual-ported memory manager are:
rtems.port_create
- Create a port
rtems.port_ident
- Get ID of a port
rtems.port_delete
- Delete a port
rtems.port_external_to_internal
- Convert external to internal address
rtems.port_internal_to_external
- Convert internal to external address
