RTEMS Logo
RTEMS 4.6.99.3 On-Line Library
Transmitter Thread
PREV UP NEXT Bookshelf RTEMS Network Supplement
6.4.4: Transmitter Thread
This thread is also event driven. Each time an Ethernet frame is put in the transmit queue, an event is sent to the transmit thread, which empty the queue by sending each outcoming frame. Because we use only one transmit buffer, we are sure that the frame is well-sent before sending the next.
