RTEMS Logo
RTEMS 4.6.99.3 On-Line Library
BOOTP/DHCP operation
PREV UP NEXT Bookshelf RTEMS Network Supplement
4.4: BOOTP/DHCP operation
Set up a BOOTP/DHCP server on the network. Set define RTEMS USE_BOOT in networkconfig.h. Run the netdemo test program. Verify that the target system configures itself from the BOOTP/DHCP server and that all the above tests succeed.
