RTEMS 4.6.99.3 On-Line Library
Preliminary Setup
RTEMS Network Supplement
4.1: Preliminary Setup
The network used to test the driver should include at least:
- The hardware on which the driver is to run.
It makes testing much easier if you can run a debugger to control
the operation of the target machine.
- An Ethernet network analyzer or a workstation with an
`Ethernet snoop' program such as
ethersnoop or
tcpdump.
- A workstation.
During early debug, you should consider putting the target, workstation,
and snooper on a small network by themselves. This offers a few
advantages:
- There is less traffic to look at on the snooper and for the target
to process while bringing the driver up.
- Any serious errors will impact only your small network not a building
or campus network. You want to avoid causing any unnecessary problems.
- Test traffic is easier to repeatably generate.
- Performance measurements are not impacted by other systems on
the network.
