RTEMS Logo
RTEMS 4.6.99.3 On-Line Library
Tapping Into an Interface
PREV UP NEXT Bookshelf RTEMS Network Supplement
3.4.2: Tapping Into an Interface
RTEMS add two new ioctls to the BSD networking code: SIOCSIFTAP and SIOCGIFTAP. These may be used to set and get a tap function. The tap function will be called for every Ethernet packet received by the interface.
These are called like other interface ioctls, such as SIOCSIFADDR. When setting the tap function with SIOCSIFTAP, set the ifr_tap field of the ifreq struct to the tap function. When retrieving the tap function with SIOCGIFTAP, the current tap function will be returned in the ifr_tap field. To stop tapping packets, call SIOCSIFTAP with a ifr_tap field of 0.
The tap function is called like this:
int tap (struct ifnet *, struct ether_header *, struct mbuf *)
The tap function should return 1 if the packet was fully handled, in which case the caller will simply discard the mbuf. The tap function should return 0 if the packet should be passed up to the higher networking layers.
The tap function is called with the network semaphore locked. It must not make any calls on the application levels of the networking level itself. It is safe to call other non-networking RTEMS functions.
