RTEMS Logo
RTEMS 4.6.99.3 On-Line Library
Write the Driver Statistic-Printing Function
PREV UP NEXT Bookshelf RTEMS Network Supplement
2.12: Write the Driver Statistic-Printing Function
This function should print the values of any statistic/diagnostic counters the network driver may use. The driver ioctl function should call the statistic-printing function when the ioctl command is SIO_RTEMS_SHOW_STATS.
