The region manager provides facilities to dynamically allocate memory in variable sized units. The directives provided by the region manager are:
rtems_region_create - Create a region
rtems_region_ident - Get ID of a region
rtems_region_delete - Delete a region
rtems_region_extend - Add memory to a region
rtems_region_get_segment - Get segment from a region
rtems_region_return_segment - Return segment to a region
rtems_region_get_segment_size - Obtain size of a segment
