RTEMS Logo
RTEMS 4.6.5 On-Line Library
Input and Output Primitives Manager read - Reads from a file.
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
5.4.5: read - Reads from a file.
CALLING SEQUENCE:
#include <unistd.h>
int read(
  int           fildes,
  void         *buf,
  unsigned int  nbyte
STATUS CODES:
On error, this routine returns -1 and sets errno to one of the following:
EAGAIN
The O_NONBLOCK flag is set for a file descriptor and the process would be delayed in the I/O operation.
EBADF
Invalid file descriptor
EINTR
Function was interrupted by a signal.
EIO
Input or output error
DESCRIPTION:
The read() function reads nbyte bytes from the file associated with fildes into the buffer pointed to by buf.
The read() function returns the number of bytes actually read and placed in the buffer. This will be less than nbyte if:
When attempting to read from any empty pipe or FIFO:
When attempting to read from a file other than a pipe or FIFO and no data is available.
NOTES:
NONE
