RTEMS 4.6.5 On-Line Library
Process Environment Manager ttyname_r - Reentrant Determine Terminal Device Name
RTEMS POSIX API User's Guide
3.4.21: ttyname_r - Reentrant Determine Terminal Device Name
CALLING SEQUENCE:
int ttyname_r(
int fd,
char *name,
int namesize
STATUS CODES:
This routine returns -1 and sets errno
as follows:
- EBADF
If not a valid descriptor for a terminal device.
- EINVAL
If
name
is NULL or namesize
are insufficient.
DESCRIPTION:
This service the pathname of the terminal device that is open
on the file descriptor fd
NOTES:
NONE
