* This file contains an example of a simple RTEMS
* application. It instantiates the RTEMS Configuration
* Information using confdef.h and contains two tasks:
* a * user initialization task and a simple task.
* This example assumes that a board support package exists.
rtems_task user_application(rtems_task_argument argument);
rtems_task init_task(
rtems_task_argument ignored
rtems_id tid;
rtems_status_code status;
rtems_name name;
name = rtems_build_name( 'A', 'P', 'P', '1' )
status = rtems_task_create(
name, 1, RTEMS_MINIMUM_STACK_SIZE,
RTEMS_NO_PREEMPT, RTEMS_FLOATING_POINT, &tid
if ( status != RTEMS_STATUS_SUCCESSFUL ) {
printf( "rtems_task_create failed with status of %d.\n", status );
exit( 1 );
status = rtems_task_start( tid, user_application, 0 );
printf( "rtems_task_start failed with status of %d.\n", status );
exit( 1 );
status = rtems_task_delete( SELF ); /* should not return */
printf( "rtems_task_delete returned with status of %d.\n", status );
exit( 1 );
/* application specific initialization goes here */
while ( 1 ) { /* infinite loop */
/* APPLICATION CODE GOES HERE
* This code will typically include at least one
* directive which causes the calling task to
* give up the processor.
#define CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER /* for stdio */
#define CONFIGURE_TEST_NEEDS_CLOCK_DRIVER /* for time services */
#define CONFIGURE_MAXIMUM_TASKS 2
#define CONFIGURE_INIT_TASK_NAME rtems_build_name( 'E', 'X', 'A', 'M' )
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#include <confdefs.h>
