The RTEMS Configuration Table is used to tailor an
application for its specific needs. For example, the user can
configure the number of device drivers or which APIs may be used.
THe address of the user-defined Configuration Table is passed as an
argument to the rtems.initialize_executive
directive, which MUST be the first RTEMS directive called.
is defined in the following Ada record:
type Configuration_Table is record Work_Space_Start : RTEMS.Address; Work_Space_Size : RTEMS.Unsigned32; Maximum_Extensions : RTEMS.Unsigned32; Microseconds_Per_Tick : RTEMS.Unsigned32; Ticks_Per_Timeslice : RTEMS.Unsigned32; Maximum_Devices : RTEMS.Unsigned32; Number_Of_Device_Drivers : RTEMS.Unsigned32; Device_Driver_Table : RTEMS.Driver_Address_Table_Pointer; Number_Of_Initial_Extensions : RTEMS.Unsigned32; User_Extension_Table : RTEMS.Extensions_Table_Pointer; User_Multiprocessing_Table : RTEMS.Multiprocessing_Table_Pointer; RTEMS_API_Configuration : RTEMS.API_Configuration_Table_Pointer; POSIX_API_Configuration : RTEMS.POSIX_API_Configuration_Table_Pointer; end record; type Configuration_Table_Pointer is access all Configuration_Table;
When using the confdefs.h
mechanism for configuring
an RTEMS application, the value for this field corresponds
to the setting of the macro CONFIGURE_EXECUTIVE_RAM_WORK_AREA
which defaults to NULL
. Normally, this field should be
configured as NULL
as BSPs will assign memory for the
RTEMS RAM Workspace as part of system initialization.
confdefs.h
to the setting of the macro CONFIGURE_EXECUTIVE_RAM_SIZE
and is calculated based on the other system configuration settings.
confdefs.h
to the setting of the macro CONFIGURE_MICROSECONDS_PER_TICK
If not defined by the application, then the
macro defaults to 10000
(10 milliseconds).
confdefs.h
to the setting of the macro CONFIGURE_TICKS_PER_TIMESLICE
confdefs.h
to the setting of the macro CONFIGURE_MAXIMUM_DEVICES
confdefs.h
to the setting of the macro CONFIGURE_MAXIMUM_DRIVERS
This value is set to maximum_devices
if it is greater
than maximum_drivers
User_driver_address_table
entry should be NULL.
an RTEMS application, the value for this field is calculated
automatically based on the number of entries in the
Device Driver Table. This calculation is based on the assumption
that the Device Driver Table is named Device_drivers
and defined in C. This table may be generated automatically
for simple applications using only the device drivers that correspond
to the following macros:
CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
Note that network device drivers are not configured in the Device Driver Table.
confdefs.h
an RTEMS application, the Device Driver Table is assumed to be
and defined in C. If the application is providing
its own Device Driver Table, then the macro
CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
must be defined to indicate
this and prevent confdefs.h
from generating the table.
confdefs.h
to the setting of the macro CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS
which is set automatically by confdefs.h
based on the size
of the User Extensions Table.
confdefs.h
an RTEMS application, the User Extensions Table is named
Configuration_Initial_Extensions
and defined in
confdefs.h. It is initialized based on the following
macros:
CONFIGURE_INITIAL_EXTENSIONS
STACK_CHECKER_EXTENSION
The application may configure one or more initial user extension
sets by setting the CONFIGURE_INITIAL_EXTENSIONS
macro. By
defining the STACK_CHECKER_EXTENSION
macro, the task stack bounds
checking user extension set is automatically included in the
application.
confdefs.h
an RTEMS application, the Multiprocessor Configuration Table
is automatically generated when the CONFIGURE_MP_APPLICATION
is defined. If CONFIGURE_MP_APPLICATION
is not defined, the this
entry is set to NULL. The generated table has the name
Multiprocessing_configuration
confdefs.h
application
configuration mechanism. The generated table has the name
Configuration_RTEMS_API
confdefs.h
application
configuration mechanism. The confdefs.h
application
mechanism will fill this field in with the address of the
Configuration_POSIX_API
table of POSIX API is configured
and NULL if the POSIX API is not configured.
