Requirement We Will Take Into Account For the First Implementation
RTEMS Remote Debugger Server Specifications
3.3.1: Requirement We Will Take Into Account For the First Implementation
[(R1)]:
Obviously.
[(R2)]:
As these are our targets. Of course other will be free to contribute.
We will however document the works that needs to be done in order to port the
debug code to other processors,
[(R3)]:
We think it is feasible with only few RTEMS modifications,
[(R5)]:
We think serial line debugging is nowadays too restrictive as most equipment
are now connected via Ethernet,
[(R6)]:
This is a documentation problem and should be fairly easy to describe
once we have the RGDBSD code,
[(R9)]:
We will try to provide the multi-thread target system presentation,
