BSP and Device Driver Development Guide
The IDE Controller driver is responsible for providing an interface to an IDE Controller. The capabilities provided by this driver are:
The reference implementation for an IDE Controller driver can
be found in $RTEMS_SRC_ROOT/c/src/libchip/ide
. This driver
is based on the libchip concept and allows to work with any of the IDE
Controller chips simply by appropriate configuration of BSP. Drivers for a
particular IDE Controller chips locate in the following directories: drivers
for well-known IDE Controller chips locate into
, drivers for IDE Controller chips
integrated with CPU locate into
$RTEMS_SRC_ROOT/c/src/lib/libcpu/myCPU
and
drivers for custom IDE Controller chips (for example, implemented on FPGA)
locate into $RTEMS_SRC_ROOT/c/src/lib/libbsp/myBSP
There is a README file in these directories for each supported
IDE Controller chip. Each of these README explains how to configure a BSP
for that particular IDE Controller chip.
