BSP and Device Driver Development Guide
The Real-Time Clock (RTC) driver is responsible for providing an interface to an RTC device. [NOTE: In this chapter, the abbreviation TOD is used for Time of Day.] The capabilities provided by this driver are:
The reference implementation for a real-time clock driver can
be found in c/src/lib/libbsp/shared/tod.c
. This driver
is based on the libchip concept and can be easily configured
to work with any of the RTC chips supported by the RTC
chip drivers in the directory c/src/lib/lib/libchip/rtc
There is a README file in this directory for each supported
RTC chip. Each of these README explains how to configure the
shared libchip implementation of the RTC driver for that particular
RTC chip.
The DY-4 DMV177 BSP uses the shared libchip implementation of the RTC
driver. Its RTC_Table
configuration table can be found in
c/src/lib/libbsp/powerpc/dmv177/tod/config.c
