BSP and Device Driver Development Guide
When the microprocessor accesses a memory area, address decoding is handled by an address decoder, so that the microprocessor knows which memory chip(s) to access. The following figure illustrates this:
+-------------------+ ------------| | ------------| |------------ ------------| Address |------------ ------------| Decoder |------------ ------------| |------------ ------------| | +-------------------+ CPU Bus Chip Select
The Chip Select registers must be programmed such that they match
the linkcmds
settings. In the gen68340 BSP, ROM and RAM
addresses can be found in both the linkcmds
and initialization
code, but this is not a great way to do this. It is better to
define addresses in the linker script.
