rtems_status_code rtems_timer_create( rtems_name name, rtems_id *id );
RTEMS_SUCCESSFUL
- timer created successfully
RTEMS_INVALID_ADDRESS
- id
is NULL
RTEMS_INVALID_NAME
- invalid timer name
RTEMS_TOO_MANY
- too many timers created
This directive creates a timer. The assigned timer id is returned in id. This id is used to access the timer with other timer manager directives. For control and maintenance of the timer, RTEMS allocates a TMCB from the local TMCB free pool and initializes it.
This directive will not cause the calling task to be preempted.
