RTEMS Logo
RTEMS 4.6.2 On-Line Library
Task Manager TASK_VARIABLE_DELETE - Remove per task variable
PREV UP NEXT Bookshelf RTEMS C User's Guide
5.4.17: TASK_VARIABLE_DELETE - Remove per task variable
CALLING SEQUENCE:
rtems_status_code rtems_task_variable_delete(
  rtems_id  tid,
  void    **task_variable
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - per task variable added successfully
RTEMS_INVALID_ID - invalid task id
RTEMS_NO_MEMORY - invalid task id
RTEMS_INVALID_ADDRESS - task_variable is NULL
RTEMS_ILLEGAL_ON_REMOTE_OBJECT - not supported on remote tasks
DESCRIPTION:
This directive removes the given location from a task's context.
NOTES:
NONE
