The RTEMS User Extensions Manager allows the application developer to augment the executive by allowing them to supply extension routines which are invoked at critical system events. The directives provided by the user extensions manager are:
rtems.extension_create
- Create an extension set
rtems.extension_ident
- Get ID of an extension set
rtems.extension_delete
- Delete an extension set
