procedure Timer_Cancel ( ID : in RTEMS.ID; Result : out RTEMS.Status_Codes );
RTEMS.SUCCESSFUL
- timer canceled successfully
RTEMS.INVALID_ID
- invalid timer id
This directive cancels the timer id. This timer will
be reinitiated by the next invocation of rtems.timer_reset
rtems.timer_fire_after
, or
rtems.timer_fire_when
with this id.
This directive will not cause the running task to be preempted.
