RTEMS Logo
RTEMS 4.6.2 On-Line Library
Clock Manager CLOCK_GET - Get system date and time information
7.4.2: CLOCK_GET - Get system date and time information
CALLING SEQUENCE:
procedure Clock_Get (
   Option      : in     RTEMS.Clock_Get_Options;
   Time_Buffer : in     RTEMS.Address;
   Result      :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - current time obtained successfully
RTEMS.NOT_DEFINED - system date and time is not set
RTEMS.INVALID_ADDRESS - time_buffer is NULL
DESCRIPTION:
This directive obtains the system date and time. If the caller is attempting to obtain the date and time (i.e. option is set to either RTEMS.CLOCK_GET_SECONDS_SINCE_EPOCH, RTEMS.CLOCK_GET_TOD, or RTEMS.CLOCK_GET_TIME_VALUE) and the date and time has not been set with a previous call to rtems.clock_set, then the RTEMS.NOT_DEFINED status code is returned. The caller can always obtain the number of ticks per second (option is RTEMS.CLOCK_GET_TICKS_PER_SECOND) and the number of ticks since the executive was initialized option is RTEMS.CLOCK_GET_TICKS_SINCE_BOOT).
The option argument may taken on any value of the enumerated type rtems_clock_get_options. The data type expected for time_buffer is based on the value of option as indicated below:
NOTES:
This directive is callable from an ISR.
This directive will not cause the running task to be preempted. Re-initializing RTEMS causes the system date and time to be reset to an uninitialized state. Another call to rtems.clock_set is required to re-initialize the system date and time to application specific specifications.
