RTEMS Logo
RTEMS 4.6.1 On-Line Library
Debug Session Example
PREV UP next Bookshelf RTEMS/GDB User's Guide
Chapter 6: Debug Session Example
The following is a debug session. Note that some lines have been broken to aviod formatting problems in the printed document.
GNU gdb 4.17
Copyright 1998 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and
you are welcome to change it and/or distribute copies of it under
certain conditions.  Type "show copying" to see the conditions.
There is absolutely no warranty for GDB.
Type "show warranty" for details.
This GDB was configured as --host=i686-pc-linux-gnu --target=i386-rtems.
(gdb) setrpcmode sun
(gdb) setdaemontype rdbg
(gdb) target rtems usnet-test
Attaching remote machine across net...
Connected to usnet-test.
Now the "run" command will start a remote process.
(gdb) file /buildr4/pc386/tests/debug.exe
Reading symbols from /buildr4/pc386/tests/debug.exe...done.
(gdb) attach 1
Attaching program: /buildr4/pc386/tests/debug.exe pid 1
0x22fe65 in enterRdbg ()
(gdb) info threads
There are 8 threads:
Id.               Name       Detached   Suspended
134283273         Rini       No         No <= current target thread
134283272         Evnt       No         No
_Thread_Dispatch () at /rtems4/cpukit/score/src/thread.c:315
134283271         SPE2       No         No
134283270         SPE1       No         No
_Thread_Handler () at /rtems4/cpukit/score/src/thread.c:1107
134283269         RDBG       No         No
134283268         SCrx       No         No
134283267         SCtx       No         No
134283266         ntwk       No         No
(gdb) b init.c:92
Breakpoint 1 at 0x200180: file \
       /rtems4/c/src/tests/samples/debug/init.c, line 92.
(gdb) c
Continuing.
Thread 134283273 (Rini) has been deleted.
[Switching to Rtems thread 134283271 (Not suspended) \
    ( <= current target thread )]
Breakpoint 1, example2 (argument=4) at \
    /rtems4/c/src/tests/samples/debug/init.c:92
92 tuto += tuti;
(gdb) b init.c:66
Breakpoint 2 at 0x200128: file \
    /rtems4/c/src/tests/samples/debug/init.c, line 66.
(gdb) c
Continuing.
[Switching to Rtems thread 134283270 (Not suspended) \
Breakpoint 2, example1 (argument=4) at \
    /rtems4/c/src/tests/samples/debug/init.c:66
66 toto += titi;
(gdb) c
Continuing.
92 tuto += tuti;
(gdb) s
93 if (print_enable2)
(gdb) detach
Detaching program: /buildr4/pc386/tests/debug.exe pid 1
Warning: the next command will be done localy!
If you want to restart another remote program, reuse the target command
(gdb) quit
