The rtems_rate_monotonic_delete
directive is used to delete
a rate monotonic period. If the period is running and has not
expired, the period is automatically canceled. The rate
monotonic period's control block is returned to the PCB free
list when it is deleted. A rate monotonic period can be deleted
by a task other than the task which created the period.
